Displays the RTEP L2PT configuration and status of a service.
| vlan | Specifies the VLAN configuration. |
| vlan_name | Specifies the VLAN name. |
| vxlan | Specifies Virtual eXtensible LAN. |
| vr | Specifies Virtual Router. |
| vr_name | Specifies the Virtual Router Name. If not specified, the VR of the current command context is used. |
| rtep | Specifies Remote Tunnel End Point. |
| rtep_ipv4 | Specifies the Remote Tunnel End Point IPv4 address. |
| l2pt | Specifies Layer 2 protocol tunneling. |
| detail | Specifies to show L2PT configuration and status in detail. |
N/A.
Use this command to display the RTEP L2PT configuration and status of a service.
The following example illustrates the show rtep l2pt command with RTEP IP address as 2.2.2.2 of VxLAN service Interface:
# show vlan tenant vxlan rtep 2.2.2.2 l2pt Interface Profile Name ------------------------------------------------ ------------------------------- VR-Default:2.2.2.2 l2pt-none
The following is an example of the show rtep l2pt command:
# show vlan tenant l2pt Interface Profile Name ------------------------------------------------ ------------------------------- 15 l2pt-user VR-Default:2.2.2.2 l2pt-none
The following example illustrates the show rept l2pt detail command with RTEP IP address as 2.2.2.2 of VxLAN service Interface:
# show vlan tenant vxlan rtep 2.2.2.2 l2pt detail
VXLAN RTEP: VR-Default:2.2.2.2
L2PT Profile Name : l2pt-none
Protocol Filter Name : cdp
Destination Address: 01:00:0c:cc:cc:cc
Protocol Id Type : snap
Protocol Id Value : 0x2000
Field Offset :
Field Value :
Field Mask :
Action : None
CoS :
DSCP : 50
DSCP Replace : Yes
Packets Transmitted: 0
Packets Received : 0
The following example illustrates the show rtep l2pt detail command:
# show vlan tenant l2pt detail
Port 15
L2PT Profile Name : l2pt-user
Field Offset :
Field Value :
Field Mask :
Action : Tunnel
CoS :
DSCP : 50
DSCP Replace : Yes
Packets Transmitted: 10956
Packets Received : 11492
Field Offset :
Field Value :
Field Mask :
Action : None
CoS :
DSCP : 50
DSCP Replace : Yes
This command was first available in ExtremeXOS 31.3.
This command is supported on the ExtremeSwitching 5520 series switch and stacks with 5520 slots only.
